Jumo
Horizontal version
The Nesos R40 LSH from Jumo is a new member of the Nesos series, which includes devices for point level measurement using a float and reed contact and for level measurement using a float and reed chain.
© Jumo
Thanks to its horizontal design, the float switch can be easily mounted on the side walls of tanks and containers and then reliably measures the respective limit level (MIN/MAX level). The measurement is independent of many medium properties, pressure ratios and container geometries. For redundant level measurement, it offers up to two switching contacts for which no auxiliary energy (power supply) is required.
The float switch from Jumo is available with a sliding tube length of up to 1 m and can be used at temperatures from -52 to +240 °C and process pressures up to a maximum of 88 bar. It is available in protection classes IP65 to IP68 and is optionally available with ATEX and IECEx approval for use in Zone 0. A version with a temperature sensor/switch is also available in the product range.
Jumo
A year of restrictions
"Getting off lightly" - this is how Managing Director Dimitrios Charisiadis summarizes the past few months for Jumo in a virtual press conference. The outlook for the company's future is optimistic.
Jumo
Continuously measured
Safety PLCs are not always necessary to implement safety requirements in tank systems. In some cases, the use of safety monitors or limiters is also sufficient.
Jumo
Supplemented by three modules
The Varitron automation system from Jumo is being extended by three modules: The 32-channel digital I/O module offers 32 channels, 17 of which are configured as digital outputs as standard.
Electrosil
Dynamic haptic feedback
With the 'Smart-Knob Mini', Elektrosil is expanding its series of intelligent rotary pushbuttons with a compact solution. The rotary encoder combines rotation and pressure functionality in a robust housing with IP65 protection and a glass surface.
