Jumo
Single/two-channel controller with PLC function
The multifunctional Merotron controller from Jumo has a customizable device menu for user-friendly integration into a wide range of applications.
© Jumo
Operation, configuration, parameterization and process information are user-friendly and provided in plain text in four languages. Quick commissioning is possible thanks to the push-in terminal technology. Scalable hardware with plug-and-play functionality ensures planning reliability. Users can expand the connection options themselves using optional plug-in cards. For example, versions with up to 14 digital inputs, five analog inputs or ten relay outputs are available. Calibration of the analog inputs in accordance with CQI-9 and AMS2750 is possible as an option.
Profinet, Ethernet and RS485 (Modbus master/slave for TCP and RTU) as well as Bluetooth, USB host and device are available for communication with the Jumo controller. It can be used as a two-point and three-point controller, three-point stepping controller, positioner, continuous controller and program controller with real-time clock. Four analog and four digital values can be recorded via an integrated data logger.
Jumo
Intelligent automation
Jumo has put together its automation portfolio on one wall: Sensors for various measured variables, two automation systems, software for process control and visualization as well as a cloud solution, supplemented by engineering services.
Jumo
A year of restrictions
"Getting off lightly" - this is how Managing Director Dimitrios Charisiadis summarizes the past few months for Jumo in a virtual press conference. The outlook for the company's future is optimistic.
Jumo
Horizontal version
The Nesos R40 LSH from Jumo is a new member of the Nesos series, which includes devices for point level measurement using a float and reed contact and for level measurement using a float and reed chain.
Hima Group
20 % increase in sales in 2023
Hima, a provider of safety-related automation solutions, has closed the 2023 financial year as the most successful in the company's history to date. In addition to its global presence, the solution portfolio for the process industry and railroad...
