Measuring amplifier
Althen Sensors & Controls | Inka Krischke,
Digitize weighing systems
With the help of the universal measuring amplifier LCB from Althen Sensors & Controls, the analog measuring signal (mV/V) of a strain gauge sensor is converted into a digital signal and is thus IoT-compatible.
© Althen
 This means that the existing load cell can still be used when a measurement chain is digitized at a later date, and there is no need to replace existing analog sensors. The connection with PLCs can be made via various fieldbus types. The measuring amplifier is configured via the Micro-USB interface. It is suitable for use in the food and packaging, beverage, pharmaceutical, chemical, steel, transport, rail and bulk goods industries.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
