Simulation software
Quelle: ISG Industrielle Steuerungstechnik GmbH,
Using digital twins
The revised version 2.8 of the ISG-virtuos simulation system - an open platform for digital twins - will be presented by ISG Industrielle Steuerungstechnik. According to the provider, this shortens time-to-market and reduces commissioning time by up to 90%.
© ISG Industrial Control Technology
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
