Software
Quelle: T&G Automation | Lukas Dehling,
Conforms to ISO-50001
Mepis Energy from T&G is suitable for linking previously isolated systems with each other. A wide variety of data can be recorded and transferred to a higher-level management system via various communication channels such as S0 bus, M-Bus, CAN bus or Ethernet.
© T & G Automation
The data can be cached in selected historians and analyzed in a user-friendly way. They can then be called up in clear reports or dashboards on mobile and permanently installed end devices. It is also possible to allocate specific consumption to individual buildings, departments or machines, as required by ISO 50002. The software is manufacturer-neutral and communicates upwards with ERP or control technology and downwards with the individual data loggers. All common protocols and fieldbuses are supported. The measured value queries generated by the devices can be customized, as can the respective transmission intervals. Anything up to a millisecond cycle is possible. The collected values are checked for plausibility and an alarm is sent to the responsible persons if limit values are exceeded. The software not only monitors the target and actual values of various process parameters, but also compliance with cost or emission restrictions and the conformity of test results with certain quality specifications after appropriate configuration.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
