Cooperation
Yaskawa and Phoenix Contact announce partnership
Yaskawa and Phoenix Contact have agreed a partnership to utilize Phoenix Contact's 'PLCnext Technology' in the development of next generation machine control platforms.
PLCnext Technology: Basis of the open control platform from Phoenix Contact
© Phoenix Contact
The companies' common goal is to offer an open and future-proof ecosystem for industrial automation. In this context, Phoenix Contact has licensed the 'PLCnext' runtime environment to Yaskawa and agrees to future joint developments.
Yaskawa, a manufacturer of drive and control technology, robotics and frequency inverters, sees 'PLCnext Technology' as the most open of the automation platforms available today, combining IEC 61131-3 programming, modern programming languages, safety hardware and software, and the safety of industrial control systems. The company will use 'PLCnext Technology' to further expand and develop its range of machine control systems.
PLCnext Technology is an open ecosystem for industrial automation from Phoenix Contact. With its combination of open control technology, modular engineering software and online community, this solution enables easy adaptation to changing requirements and the efficient use of existing and new software applications.
Ulrich Leidecker, President Business Area Industrial Management and Automation (IMA) at Phoenix Contact, explains: "The technology partnership with Yaskawa is a milestone for the automation industry, because the more partners there are in an open automation ecosystem, the more valuable and powerful it becomes for each individual participant."
"Bringing PLCnext Technology together with Yaskawa's proven motion control engine and robust controller hardware creates a control platform that is open, flexible and powerful, based on the proven PLCopen toolbox solutions for logic control, machine control and control of delta and articulated arm robots," said John Payne, Senior Vice President Motion at Yaskawa America. "The new Yaskawa platform will combine controllers for logic, machine control and robotics with solutions for Industry 4.0 applications. It will also expand Yaskawa's control technology offering with solutions for network security and control system safety."
Phoenix Contact
Retired CTO
Roland Bent, CTO of Phoenix Contact, ended his professional life on February 28. His core responsibilities will be assumed by CDO Frank Possel-Dölken from March 1, with a focus on the digitalization of Phoenix Contact.
Yaskawa
Extension via CPU
The control and I/O systems of the 'SLIO' series from Yaskawa can be supplemented 'slice by slice' with the required I/O modules and thus adapted to the respective automation task.
Phoenix Contact
M12 with push-pull locking
Phoenix Contact is expanding its portfolio of M12 connectors with push-pull quick locking and is making the A-, D- and L-coded device connectors with pin contacts available with the matching push-pull housing screw connections for SMD and THR...
Phoenix Contact
System availability ensured
Even if only one component fails, the entire machine or system can - in the worst case - come to a standstill, as their functions are usually closely interlinked. To prevent this worst-case scenario, every fault must be safely shut down.
Yaskawa
More power for the Cobot
With the Motoman HC20DT IP67, Yaskawa is expanding its current range of collaborative robots with a significantly larger model that is designed for a higher payload and an extended working range.
