Industrial PCs
Quelle: Beckhoff Automation | Lukas Dehling,
Entry-level class with Intel processor
Beckhoff is expanding its entry-level IPC class with two devices: the C6905 control cabinet PC and the CP6706 Panel PC.
© Beckhoff Automation
Equipped with a powerful Intel Atom processor with up to four cores, the devices are particularly suitable for small and medium-sized machine control systems where motion applications or more complex graphics applications are also to be implemented, according to the manufacturer. Both the 3.5-inch motherboard and the aluminum housing have been newly developed with aspects such as industrial suitability and long-term availability in mind. The devices offer 2 GByte DDR3L RAM (expandable ex works to 8 GByte), an on-board dual Ethernet adapter with 2 × 100/1000Base-T connection, a 4 GBC fast card with high-quality SLC flash, four USB 2.0 ports, a DVI connection and an optional third Ethernet port. In addition to Windows Embedded Compact, Windows Embedded Standard and Windows 10 can be used with the new devices.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
