I/O systems
Quelle: B&R Industrie-Elektronik | Inka Krischke,
Condition monitoring included
The X90 modular control and I/O system from B&R is now available with condition monitoring functions. This allows faults that lead to spontaneous machine downtimes to be detected and rectified at an early stage.
© B&R Industrial Electronics
With the X90 module, the condition of a machine can be permanently monitored and the results allow conclusions to be drawn about the need for maintenance of the individual parts. Typical applications include the continuous monitoring of rotating machine parts such as hydraulic units, belts, gears or motors. The processed sensor data is also available in the application. The optional board for condition monitoring is used for the early detection of fault conditions on mobile machinery.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
