Rutronik
For demanding graphics performance
The D3713-V/R series mini-ITX boards from Kontron offer a wide range of models for different performance classes.
The integrated AMD Radeon Vega Graphics Compute Units and the integrated Multimedia H.265 Encoding & Decoding are particularly suitable for applications with high graphical requirements. According to the provider, the Mini-ITX board supports various processors depending on the required performance, such as the AMD Ryzen Embedded
R1000 Dual Core with a base frequency of 1.5 GHz and 8 to 10 W or the AMD Ryzen Embedded V1000 Quad Core with 3.35 GHz and 35 to 54 W.
The board is suitable for the digital signage market, medical displays, thin clients and industrial PCs, for example. The features include up to four display ports, an embedded display port and a dual-channel LVDS (24 bit). This allows a maximum of four independent displays to be operated in 4K resolution. The 170 mm × 170 mm board works optimally at temperatures from 0 to +70 °C and a humidity of 5 to 85 %.
