Cincoze
Embedded computers for the Internet of Energy
The 'DV-1000' embedded computer from Cincoze's Rugged Computing - Diamond product line is particularly suitable for applications in the Internet of Energy (IoE).
The IoE connects devices, machines and systems used in energy generation, transmission and use through sensors, controls and software. IoE delivers energy where and when it is needed through intelligent power storage and distribution and enables forecasting through big data analytics and machine learning. Cincoze 's embedded computer is compact (about the size of an A5 paper (224 x 162 x 64 mm)), and can be easily installed in any small outdoor cabinet. It supports a 9th/8th generation Intel Core i7/i5/i3 processor (Coffee Lake-R S series) and up to 32 Gbytes of DDR4 memory at 2666 MHz, which provides the computing power for real-time processing and analysis of large amounts of data and meets the high computing requirements for IoE.
The computer has the most common I/O interfaces required for IoE applications, including 2× GbE LAN, 2× COM and 6× USB, which can be connected to various types of sensors and other devices. For further expansion, COM and DIO ports can be added using Cincoze's CMI modularization technology, USB 3.0 and GbE LAN can be added using MEC modules. The computer operates in a temperature range of -40 to +70 °C, supports a wide input voltage (9 to 48 V(DC)) and has passed the shock and vibration tests according to the military standard MIL-STD-810G. If a processor with a higher wattage is used for high-speed operation, the computer can be equipped with a special external fan. To prevent electromagnetic interference in the housing, the DV-1000 has received EMC certification, including CE, UKCA, FCC, ICES-003 Class A and other multinational EMC standards.
