Cincoze
IPC for IIoT gateway
The compact and energy-efficient industrial PC 'DA-1200' from Cincoze is suitable for IIoT gateways in modern industrial applications.
© Cincoze
The IPC from Cincoze can be used in harsh environments and is particularly suitable for capturing device data, performing edge computing and transferring data between devices and cloud services. With dimensions of 150 mm × 105 mm × 52.3 mm, the industrial PC is small enough to be installed at the base of a robot arm or other space-constrained devices and has additional protection for harsh manufacturing environments. It handles a wide range of temperatures and voltages, has an integrated top cover and anti-vibration kit, is cable- and jumperless and meets various certifications and standards, including the US military standard for shock and vibration protection (MIL-STD-810H), EMC certification for industrial environments (IEC 61000-6-2/4) and UL safety certification. All important setting buttons and switches including reset, CMOS clear, AT/ATX and SIM card are located on the front panel.
