Cincoze
Robust embedded PC with a small footprint
Cincoze launches the DV-1000 embedded PC from the 'Rugged Computing-Diamond' product line.
© Cincoze
The embedded PC supports 12th and 13th generation Intel Core CPUs and up to 32Gbytes of DDR5 4800MHz memory; it also features high-speed NVMe SSD storage to maximize processing performance. Measuring only 224.1 mm x 162 mm x 62 mm and supporting 2.5G LAN and 10G USB3.2 Gen2x1, the DV-1100 embedded PC is Cincoze's smallest high-performance model. It is suitable for industrial applications such as machine vision and real-time image monitoring that require a computer with a small footprint and high-speed communication. The computer has integrated M.2 Key B and Key E slots, I/O and IGN functions can be added with exclusive Cincoze CMI and CFM modules. In terms of standards, the embedded PC complies with EN 50155 (EN 50121-3-2 only) for railroad computing, the US military standard for shock and vibration resistance MIL-STD-810H and the EMC test standard for industrial environments (EN IEC 61000-6-2 and EN IEC 61000-6-4).
The "living" e-paper
Screen Edition 2024
Welcome to the first issue of the 'Screen Edition', which opens up a completely new way of reading and informing yourself: With the Screen Edition, we offer you a dynamic and always up-to-date source of information with its finger on the pulse.
