Sigmatek
Wireless CPU communication
The compact WiFi-C and WiFi-Pro WLAN adapters from Sigmatek enable efficient and wireless CPU communication.
With the WiFi-C and WiFi-Pro WiFi adapters from Sigmatek, the network cable can be quickly replaced. This means that automation can be integrated into the existing building IT system if no wired infrastructure is available. Another advantage is a simple online connection for maintenance in the event of a service call. The adapters operate in the 2.4 GHz frequency band and can therefore be used worldwide.
The WiFi-C plug & play device, which acts as a client, is already available. Further expansion is planned for the WiFi-Pro, where the adapter can be configured as a client or access point.
