Friedrich Lütze
Load monitoring simplified
Lütze is upgrading the 'LCOS' bus couplers for universal application options so that the LOCC-Box-Net modules can now also be operated in addition to the electronic load monitors of the LCOS CCI family.
© Friedrich Lütze
Profinet-IO, Ethercat and Ethernet/IP are available as compatible bus interfaces. Remote diagnostics via TCP/IP is possible via a separate Ethernet interface. The central features of the series include a power supply module with two electrically isolated RJ45 sockets, an electrically isolated 24 V (DC) power supply on the bus coupler and two configuration interfaces such as web page and USB.
According to the provider, connected configurations are read in automatically. Up to 64 devices or up to 80 external LOCC-Box-Net modules can be connected in line on the bus.
USB communication is implemented in accordance with USB specification 2.0 at 480 Mbit/s (USB high-speed). LEDs signal status displays for power, run and status as well as other states.
Friedrich Lütze
Easy to use
According to the supplier, the new Cat. 6A module carriers from Lütze allow data transfer points between the field and the control cabinet to be implemented more quickly and securely. One of the key features of the module rack is the significantly...
Sagittarius
Turn four into one
Intelligent, digitally networked systems are the hallmark of Industry 4.0, whose largely self-organized production is based on constant interaction between people and machines. Single Pair Ethernet is a good basis for this.
Congatec
The Edge is modular
Industrial edge servers must be extremely flexible in order to integrate the broad spectrum of tasks. Virtual machines in particular are increasingly being used to consolidate a wide range of Industry 4.0 workloads.
