Electronics enclosure
E. Dold & Söhne | Inka Krischke,
Three widths available
Dold‘s KV 4600 enclosure gives manufacturers the flexibility they need for IOT and networking automation devices.
© E. Dold & Söhne
The large enclosure front allows individual arrangement of connection terminals, display and operating elements as well as integration of common communication interfaces. With currently three available overall widths from 12.5 mm and two additional overall depths, a large number of applications can be implemented. The customized printed circuit board with a usable area of over 9500 mm² provides scope for circuit design. Push-in terminals packaged for automatic packaging meet the requirements of the reflow soldering process. According to the supplier, bus systems can be integrated according to individual specifications with little effort.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
