New cables
Icotek | Inka Krischke,
Simple to configure online
Icotek‘s split cable entry systems can be freely configured using the online assembly configurator. To do this, users click through various queries to first determine the desired frame.
© Icotek
The selected cable entry strip, cable gland or EMC cable entry is then fitted with the appropriate cable or adapter sleeves. You can also select whether the assembly is to be ‚assembled‘ or ‚loose in the bag‘. The fully configured product can then be requested online from the manufacturer.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
