IO systems
Wachendorff Prozesstechnik | Inka Krischke,
More than 80 different modules
Wachendorff introduces the G series of the functional IO system 'FnIO'. According to the company, it simplifies the acquisition of sensor/actuator data and provides communication to the PLC with over ten different industrial protocols.
© Wachendorff Prozesstechnik
More than 80 different modules for inputs and outputs as well as special functions enable users to assemble their application-specific system according to requirements and expandable at any time. The modular design of the ‚G-Series‘ enables the IO configuration required for the respective application to be simply transferred centrally to a Codesys controller or implemented remotely via a fieldbus node. The remote connection of the IO modules works with the Codesys controller from the ‚G series‘ or the Codesys+HMI control solution from the supplier, but also with controllers from other manufacturers.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
