Cables
Quelle: U.I. Lapp | Inka Krischke,
Highly abrasion-resistant PUR outer jacket
The Ölflex Chain 90 P/CP belongs to Lapp's 'Extended Line Performance' class and is designed for use in continuously moving drag chains.
© U.I. Lapp
The cable with extended maintenance intervals has a highly abrasion-resistant and notch-resistant PUR outer sheath and a cold-flexible special wire insulation made of TPE. This makes it equally suitable for indoor and outdoor use - for example in industrial drives, but also in wind turbines or electric cars, where limited space usually requires very tight bending radii. The cable is resistant to mineral oil-based lubricants, UV and weather-resistant, halogen-free and highly flame-retardant. It is also UL/cUL-certified and therefore approved for use in North America. The cable is available in an unshielded (P) or shielded (CP) version.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
