Plug connector
Quelle: Wieland Electric | Inka Krischke,
For low voltage and mains applications
With the RST Micro, Wieland Electric is launching a miniature connector with a diameter of less than 15 mm.
© Wieland Electric
The 2- to 3-pole connector, specially designed for low-voltage applications, is optimized for the interface between voltage or current sources and LED modules. It is also suitable for industrial environments; its rated data means that mains applications are also no problem. Four mechanically and color-coded plug connections ensure safe separation of different applications. Like the larger members of the 'RST' product family, the miniature connector also simplifies installation. The fully pluggable system - from the distributor to the electrical device - consists of factory-assembled and tested components. The miniature connector is also available with an optional water stop. An internal sealing system prevents moisture from penetrating and prevents damage to the entire installation.
Cable carriers
Use on deep drilling rigs
Deep drilling rigs with top drive systems are used to extract oil from the earth. Until now, manufacturers and operators have relied on so-called 'service loops' to feed cables to the systems. Now there is a new solution from Igus.
Cable glands
Plug-in and screw-on variants
Icotek has expanded the QVT-Click cable gland product family to include metric sizes 16 and 20, which are pluggable and screwable. The series is suitable for introducing pre-assembled cables and, according to the manufacturer, offers a compact and...
Industrial housing
Three aluminum series
Rose manufactures three aluminum enclosure series, each developed for specific applications and made from the cast aluminum alloy AC-AlSi 12 (Fe). External mounting channels protect the electronics in the housing from chips.
