Sagittarius
Extended by modular support rail system
The Airstream mounting rail system from Lütze is suitable for users who want to assemble a mounting frame independently and easily on site.
© Friedrich Lütze
For this purpose, the modular system was extended with predefined lengths and standardized grid dimensions corresponding to 10, 25 and 50 mm hole patterns. The mounting rail system offers up to 12 mm more depth clearance, which is particularly advantageous for special enclosures. The mounting rails also offer more flexibility for subsequent device installation: according to Lütze, additional modules can be added between the installed modules at a later date using swivel-in sliding nuts. Alternatively, complete fields in the middle of the frame can be left free for later assembly.
In addition to a snap-on edge protection that neatly seals the ends of the mounting rail, new brackets have been developed to match the mounting rail system. They enable space-saving installation of bars across the entire frame width.
The trunking system has all the relevant tests and certifications for industrial use with regard to loads such as vibration shock, corrosion and harmful gases.
Would you like a little more?
First-hand news every week - that's what the Computer&AUTOMATION newsletter offers you.
© WEKA Trade Media
Subscribe to our newsletter and keep your finger on the pulse of automation. Stay up to date with us. We provide you with the latest news, exciting interviews, guest commentaries, application-oriented technical reports and new products.
Click here to subscribe.
Friedrich Lütze
Easy to use
According to the supplier, the new Cat. 6A module carriers from Lütze allow data transfer points between the field and the control cabinet to be implemented more quickly and securely. One of the key features of the module rack is the significantly...
Sagittarius
Turn four into one
Intelligent, digitally networked systems are the hallmark of Industry 4.0, whose largely self-organized production is based on constant interaction between people and machines. Single Pair Ethernet is a good basis for this.
Sagittarius
Cooling switch cabinets as required
What to do when production facilities are 'getting on in years' and their retrofitting needs to meet both digitalization and sustainability requirements? A long-term project for temperature monitoring of control cabinets helped an automotive...
