Cable entry plates
Quelle: Murrplastik Systemtechnik | Inka Krischke,
Edges rounded to protect cables
Murrplastik's KDP-Z is a cable entry plate which, according to the supplier, can feed more cables into or through a much smaller space than comparable commercially available cable entries.
© Murrplastik system technology
Installation is carried out in just a few steps. On request, the cable entry plate is available either with a smooth surface without strain relief or with a recessed contour and strain relief. All edges are rounded to protect cables. The seal of the cable entry plate is firmly attached to the housing and thus ensures greater tightness. All screws are firmly fixed to the housing and therefore cannot be lost. The cable gland is suitable for filling and packaging machines in the food, chemical and pharmaceutical industries, for wind, oil, gas and hydroelectric power plants as well as in mechanical and plant engineering, in building technology and for cleaning systems.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
