Compact cabinet feed-throughs
Quelle: Friedrich Lütze | Inka Krischke,
Designed in protection class IP67
Lütze is launching a Cat 6A control cabinet bushing onto the market, which enables control cabinet and machine builders to implement real-time-capable 10 Gbit/s service interfaces via Profinet, Industrial Ethernet or Sercos in the extended temperature range of -45 to +85 °C.
© Friedrich Lütze
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
