Plug connector
Stäubli Electrical Connectors | Inka Krischke,
Data rates of up to 10 Gbit/s in automated applications
Stäubli offers the Gigabit Ethernet connector Giga-Dock10 for the secure and reliable transmission of signals, data and fieldbuses. It has a compact design and, according to the supplier, is designed to meet the highest demands for signal transmission at up to 10 Gbit/s.
© Stäubli Electrical Connectors
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
