Binder at the SPS 2021
Combinable M12 control cabinet feed-throughs
Binder announces new panel feed-throughs for the M12 product series 713, 813, 814, 823 and 824, which are available with different codings and pole numbers.
© Binder
The components of type M12 or M12 Power - in accordance with the DIN EN 61076-2-111 standard - enable the connection of signal, data and supply cables using similar circular connectors of the respective series. They are equipped with an M12 screw thread and an M16 fastening thread. The new bushings are available in A, S, K, L and T coding and, depending on the coding, in pole numbers 4 to 8. Various coding positions are also possible.
The technical data of the feedthroughs, such as protection class, rated voltage and current, contact resistance and others, vary from series to series according to the data of the matching M12 and M12 Power circular connectors from Binder. In general, the products meet the requirements of protection class IP67. They are designed for operating temperatures between -40 and +85 °C.
Binder at the SPS 2021: Hall 10, Stand 310
Lapp
Authorized distributors made visible online
Lapp is expanding its digital service portfolio and is the first B2B industrial company to provide its authorized distributors with a verifiable online seal from authorized.by. The company aims to create more transparency and security for buyers and...
