Circular connector
Quelle: Franz Binder | Lukas Dehling,
Attenuation values of 60 dB
Binder will be showcasing 17 new products from various areas in the circular connector sector.
© Franz Binder
For example, the company now offers M5-shielded, overmoulded cable connectors with 360-degree shielding for undisturbed data transmission thanks to attenuation values of 60 dB in the 1 GHz range. Possible applications include sensor, conveyor and storage technology. The 3-pin and 4-pin connectors are compatible with each other and can be configured according to customer requirements.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
