Cellumation
Steer conveyed goods in any direction
The celluveyor conveyor and positioning system from Cellumation consists of small conveyor cells with omnidirectional drive wheels and offers conveyor technology new design and application options for the realization of complex material flows in confined spaces.
© Cellumation
The basis for this are hexagonal conveyor modules, each with three specially arranged drive wheels. They can be used to guide the conveyed goods in any direction. The conveyor modules with their hexagonal structures can be clicked together and joined to form conveyor systems of any geometry. With the patented individual wheel control, the drive wheels are each driven individually, allowing packages to be moved completely freely on one level.
The system enables plug & play solutions and can be integrated into existing systems or used as a standalone solution. No time-consuming integration or programming is required; the modules communicate with each other and automatically recognize the system layout and the desired process sequence. Users can configure the system independently without any programming knowledge using simple graphical programs - comparable to apps on a cell phone.
SEW-Eurodrive
Drives precisely synchronized
Manufacturing processes in the food industry are very complex and require intelligence in the machine. The example of a belt-synchronized cutting system shows what an automation system for the production of Maultaschen can look like.
Fruitcore
A robot called Horst
The aim when developing Horst was to create a robot solution that is simple both mechanically and in terms of software and that is specially tailored to the needs of small and medium-sized companies. What is behind this?
PIA
Out of step?
Identify bottlenecks in complex interlinked assembly systems and quickly optimize production efficiency thanks to data transparency! - The application of an assembly system for rear axle transmissions shows that this does not have to remain a wish.
Advertorial
Drive systems taken further
A FAULHABER drive system is more than the sum of its components. When users combine products with each other, the overall performance of the system increases. Experience the FAULHABER principle of perfectly optimized parameters and interfaces for...
IoT Hotspot
Focus on cloud and edge computing
The Eclipse Foundation, currently the largest open source organization in Europe, wants to promote global industry collaboration on open source projects in strategic technologies. Mike Milinkovich, Executive Director of the Eclipse Foundation,...
