Inverter
Quelle: Siemens,
Power range from 0.75 to 630 kW
The G120X inverters from the Sinamics family from Siemens are particularly suitable for pump/fan applications in sectors such as water/wastewater, building technology and industrial environments.
© Siemens
The Sinamics G120X have a power range from 0.75 to 630 kW and can be operated with any motor. The inverters run most effectively with synchronous reluctance motors from Siemens. Sinamics G120X are designed for resource-saving operation in all voltages and supply networks. The compact design also saves space in the control cabinet. Despite the absence of an additional output choke, the inverters offer motor cable lengths of up to 150 meters. The integrated safety functions are certified to SIL3.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
