Drives technology
Dunkermotoren,
Power output 50 % higher
With the new BG 66 dMove Dunkermotoren launched a new generation of their smart BLDC motors with integrated electronics with innovative features and a power output, which is up to 50% higher than the one of the predecessor model.
© Dunkermotoren
Beside the simple speed- and positioning control, the BG 66 dMove is compatible for CANopen interfaces. But furthermore, controllable with free definable digital inputs, to provide the highest flexibility for individual customer applications. As part of a product partnership with Siemens the motor series BG 45, BG 65(S), BG 75 and BG 95 are going to be available in a specific version, which is compatible to the new Simatic Micro Drive servo drive system. Because of the simple drive configuration with the TIASelection-Tool, the time for engineering is going to be much shorter. And due to the use of Profisafe, a limited torque is guaranteed. An additional product highlight which will be presentend on SPS show is the high integrated motor unit with a hub gearbox, especially designed for AGVs.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
