Maintenance service
ABB Automation,
Forecast remaining useful life
ABB expands Service Ability Condition Monitoring for the powertrain that connects drives, motors, pumps and bearings with an option for condition-based maintenance of drives.
© ABB
The software provides early warning of unusual operating conditions that could lead to premature failure of a drive and its components. Cloud-based algorithms and statistical analyses are used to determine the stress on the components and calculate their remaining service life. If a failure is predicted before the next scheduled maintenance, measures can be taken to prevent unplanned downtime. In some cases, the new service may also reveal that the drive components are subject to less stress than usual. Then the regular intervals of preventive maintenance can be extended to achieve higher productivity and cost reductions. As a first step, ABB‘s condition-based maintenance service is available for ACS800 and ACS880 series air-cooled drives. The accuracy of the predicted remaining service life depends on the specific application. In many cases, however, the failure of drive components can be predicted one or even two years in advance.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
