B&R
Compact servo amplifier with special coating
The automation company B&R presents the ACOPOS P3 servo drive. This can be used in extreme weather conditions without any problems.
The electronics of the servo drive are protected from external influences by a special coating as standard. This enables use under aggressive atmospheric environmental conditions and at temperatures as low as -25°C, according to the manufacturer. Applications on wind turbines, in cold rooms or in dusty environments are therefore also possible. As no additional hardware is required, costs are also reduced.
