disynet
Pressure: Eleven measuring ranges, seven output signals
Disynet offers the U5300 pressure transducer from TE's 'UltraStable' line: eleven measuring ranges from 0 to 1 bar to 0 to 700 bar, seven different output signals, ten possible electrical connections and fourteen pressure connection options.
This enables alignment to the respective application. The series offers an overall accuracy of better than ±0.1 % and an overall error band of better than ±0.5 % for demanding industrial applications. All wetted parts are manufactured from 316L stainless steel. Due to the design, no O-rings, welds or organic material are exposed to the pressure media.
According to disynet, the pressure sensor measures both liquid and gas pressure, even with problematic media such as contaminated water, steam and slightly corrosive liquids. The series is available in protection classes IP65 or IP67 and works in an operating temperature range between -40 and +125 °C.
