Carlo Gavazzi
Position monitoring of protective devices
Two magnetic safety sensors complete the Carlo Gavazzi range. The MC36 and MC88 series devices are used together with the corresponding magnetic actuators to monitor the position of rotating, sliding or removable guards.
© Carlo Gavazzi
The safety magnetic sensors from Carlo Gavazzi cover the temperature range from -25 to +80 °C and are suitable for damp, dusty and dirty industrial environments thanks to protection class IP67 or IP69K. With a suitable safety module, they achieve up to SIL 4 and PL e in accordance with EN13849-1. The assured switch-on distance Sao of the MC36 safety magnetic sensors is 5 mm and the assured switch-off distance Sar is 15 mm. The MC88 series offers versions with three different permanent magnets especially for applications in which precise approach of the magnet is not possible and very large tolerances are required. With the strongest permanent magnet, the secured switch-on distance Sao is 18 mm and the secured switch-off distance Sar is 30 mm.
Carlo Gavazzi
Precise control of infrared heaters
In order to support manufacturing companies that use industrial heating applications in their orientation towards Industry 4.0, systems that can precisely switch these special heating loads and also take over the complete monitoring of the load...
