K.A. Schmersal
Solenoid interlock functionally extended
Schmersal has equipped the electronic solenoid interlock 'AZM40' with new accessories and new features.
© Schmersal
Its dimensions (119.5 mm x 40 mm x 20 mm) make it particularly suitable for small safety doors or maintenance hatches and confined installation spaces, but with a new locking clamp it can now also be used on larger, accessible machines and systems. Service staff can attach a lock to the locking tongs when entering the danger zone so that the guard door cannot be closed and unintentional start-up of the machine is prevented. In addition, the new versions of the solenoid interlock from Schmersal can be extended with an escape release or emergency unlocking. Two versions are available - with lever or push-button. Both are available as escape release and emergency release. The lever can be mounted directly on the guard locking device. The similarity of the push-button to an emergency stop button makes it intuitive to operate. The guard locking has also been extended to include protection class IP69 and a temperature range of -20 to +55 °C.
Schmersal
Motto "Sustainable!"
The EU Commission has presented a proposal for a new Ecodesign Regulation for Sustainable Products (ESPR), which is to become a central component of the European Green Deal. Schmersal is also already on the road to sustainability.
Schmersal
Services division restructured
The Schmersal Group is restructuring its service business: tec.nicum's range of safety services is being significantly expanded - particularly with regard to digitalization and complete solutions for machine safety.
Schmersal
Schmersal
