Carlo Gavazzi
Bidirectional energy meters
The bidirectional energy analyzer for single-phase systems 'EM511' complements the 'EM500' energy meter series from Carlo Gavazzi.
© Carlo Gavazzi
The Carlo Gavazzi energy analyzer covers the measuring range up to 240 V L-N nominal voltage and up to 45 A nominal current and enables real-time monitoring of energy consumption, the main electrical variables and the harmonic distortion of the load. It is suitable for measuring and monitoring consumption in energy and building efficiency applications, industrial automation and charging infrastructures for electromobility. The energy analyzer can also be used for control systems such as photovoltaic systems with battery storage and vehicle-to-grid (V2G) applications. It has a digital input for operation with two tariffs and, depending on the model, a static output (pulse or alarm), a Modbus RTU or an MBus communication interface. The update time is less than 100 ms via the serial interface and the measurement resolution is specified as 0.001 kWh.
Carlo Gavazzi
Precise control of infrared heaters
In order to support manufacturing companies that use industrial heating applications in their orientation towards Industry 4.0, systems that can precisely switch these special heating loads and also take over the complete monitoring of the load...
Vega
Level sensor with integrated cybersecurity
In January 2023, Vega delivered what is probably the world's first level sensor with integrated cybersecurity. The manufacturer of level, point level and pressure measurement technology wants to set an example against the increasing threat from...
Vega
Select process connections as required
Vega's 'Vegabar' pressure sensors and 'Vegapoint' point level switches were to be the protagonists at this year's SPS, as they made Vega a full-service provider for level and pressure in food and pharmaceutical processes at the beginning of 2020.
