TWK Electronics
Fail-safe and explosion-proof
As a SIL2/PLd encoder, the TRK78/S3 Fail-Safe over Ethercat (FSoE) encoder from TWK also meets the strict requirements for explosion protection in accordance with ATEX Directive 2014/34/EU with zones 1 (gas) and 21 (dust).
© TWK Electronics
The robust aluminum or stainless steel housing with cable connection is flameproof (Ex d). In addition, the housing is reliably sealed against the ingress of dust (Ex t) and the surface temperature does not exceed 100 °C (T5). The type 78 devices therefore comply with ATEX group II, cat. 2G (gas) with explosion group IIC and cat. 2D (dust) with explosion group IIIC. The resolution of the rotary encoder is up to 65,536 steps/360° (16 bit) with a measuring range of 4096 revolutions. In addition to the position, the rotational speed of the shaft can also be precisely recorded and read out. Different flange and shaft versions as well as the removable connection cover allow easy integration of the TRK78 into the application.
TWK
Safety encoder for AGVs
The TRK 38 from TWK is a compact and safety-oriented encoder for automated guided vehicles (AGVs) and mobile robots that helps them to navigate in space and move to target positions.
Electrosil
Dynamic haptic feedback
With the 'Smart-Knob Mini', Elektrosil is expanding its series of intelligent rotary pushbuttons with a compact solution. The rotary encoder combines rotation and pressure functionality in a robust housing with IP65 protection and a glass surface.
