BD|Sensors at the SPS 2024
Interface for Technical Gases and Hydrogen
© BD Sensors
BD|Sensors offers the industrial transmitters 'DMPB 336' for nominal pressures from 16 to 1000 bar and 'DMP 333P' with gold-plated diaphragm for nominal pressures from 60 to 600 bar especially for use in hydrogen applications.
The range of hydrogen pressure transmitters from BD|Sensors is now complemented by the 'DCT 541' with digital output signal RS485 with Modbus RTU protocol. Just like its predecessor, the new pressure transmitter is characterized by wetted components made of special stainless steel and is highly resistant to overloads and pressure peaks. In oxygen applications, the special cleaning and manufacturing process ensures that residual particles and residual hydrocarbons are greatly minimized and that no chemical reaction can occur in the production process. Thanks to the Modbus interface, the pressure transmitter provides digital output signals that are easier to transmit and process.
Hall 4A, Stand 566
Pilz
Safety and security in transformation
In modern industrial environments, safety and security are a basic requirement for efficient and reliable processes. For the transformation of industry, Pilz offers automation solutions with which machine builders and operators can ensure the...
Pepperl+Fuchs
Uncomplicated into the IIoT
A highlight exhibit at the Pepperl+Fuchs booth is a joint project with Bosch Digital Twins Industries and Syntax. Matthias Wieland from Bosch Digital Twin Industries and Hans-Günter Busch from Pepperl+Fuchs reveal the details of the predictive...
