BD|SENSORS
SPS 2025: Halle 4A, Stand 546,
Electronic pressure measurement technology for industrial applications
Reliable measurement of pressure and level - with this one competence in mind, BD|SENSORS is the full supplier of an extensive product range of electronic measuring devices for pressure and level as well as the most precise evaluation and display technology for the data obtained.
Today, the group employs over 300 people at four locations in Germany, the Czech Republic, Russia and China.
© BD|SENSORS
The company is based in Thierstein, Upper Franconia, with additional branches in the Czech Republic, China and Russia. As an innovative manufacturer of electronic measurement technology, BD|SENSORS operates worldwide and employs over 300 people - in a nutshell: a classic medium-sized family business.
Product portfolio
© BD|SENSORS
Since the company was founded, pressure sensor technology has been at the center of our activities and in almost 30 years of entrepreneurial activity, an enormously broad and deep product range has grown up that is unparalleled on the world market. Specifically, the following product groups are offered:
  • Pressure transmitter / pressure transducer
  • Differential pressure transmitter
  • Digital pressure gauges
  • Electronic pressure switches
  • Hydrostatic level probes
  • Display and evaluation units
  • Calibration services (according to DAkkS standard)
Highlights
Visit BD|SENSORS at the SPS 2025 © Computers&Automation
Proven for years and at home in numerous industrial applications - electronic pressure transmitters. They are available in many different configurations and can be customized in terms of nominal pressure range, accuracy, transmission signal, pressure connection and many other attributes. The range includes versions with Ex versions and flush-mounted designs for hygienic applications.
  • Nominal pressure range from 0 ... 10 mbar to 0 ... 8,000 bar
  • Absolute and relative pressure measurements
  • Analog and digital output signals
  • Compact and robust designs
  • Accuracy classes from 0.1 % FSO
  • Flush-mounted versions for hygienic applications
What sets BD|SENSORS apart
We offer an enormously wide range of pressure and level measurement technology. However, the strength of BD|SENSORS lies in its ability to operate outside the standard range. In other words, in practice it often happens that a product has to be individually configured or developed for an application. This is where our strength comes into play - together with the customer, we find a technically and economically suitable solution - even for small series.
Follow BD|SENSORS also in the social networks
Vega
Level measurement under extreme temperatures
Vega's high-temperature version of the 'Vegapuls 6X' radar sensor is suitable for processes at temperatures of up to +450 °C, such as iron briquetting, in which porous sponge iron mass passes through heat-resistant roller presses at temperatures of...
Gefran
Pressure transmitter with digital output
The 'KMC' pressure transmitters from Gefran have been specially developed for use in mobile hydraulics and are designed with protection class IP69K. Their digital output (CANopen and CAN SAE J1939) enables integration into various control systems.
