SPS Connect 26.11. - 12:00 - 12:20 p.m.
SPS Connect | Tiffany Dinges,
What to do in the event of security incidents?
When it comes to software and cyber security, Wago proactively supports you to protect your existing industrial automation processes in the best possible way.
Jens Sparmann is a security system specialist at Wago Kontakttechnik.
© Wago
Whenever new potential threats arise, we provide you with recommendations for action, patches and updates as quickly as possible to reduce the risk to a minimum.
Jens Sparmann, System Specialist Security at Wago Kontakttechnik, welcomes you to the presentation "What to do in the event of security incidents?".
Date: November 26, SPS Connect - 12:00 - 12:20 p.m.
Registration and tickets
To the lecture program
About Jens Sparmann
Jens Sparmann completed his training as an information electronics technician in 2008. In 2015, he successfully completed his Bachelor of Engineering and two years later his Master of Engineering.
He has been a system specialist at Wago since 2018.
Wago
Data usage in the field
Wago is launching two new edge devices, an edge controller and an edge computer. The 752-8303/8000-0002 Edge Controller from Wago works with an ARM Cortex A9 quad-core processor and has an extensive range of interfaces.
Now available
The e-paper of the November 11 issue
The e-paper of issue 11 is here. Among other things, you can read about Huawei's position in relation to the company's accusations of spying, why TSN is "a symbol of the standardization of fieldbuses" and how Single Pair Ethernet will change process...
Interview
Digitization - a spectre?
The trend towards increasing efficiency in companies through digital transformation does not stop at enclosure construction. However, many companies are hesitant when it comes to implementation. Nicole Kreie, Head of Project Service International at...
ISH
FuSi from the modular system
The development effort for functional safety is hardly affordable, especially for small and medium-sized companies - particularly from an economic point of view. A certified safety construction kit can provide a remedy here.
Wago
Strengthening cyber resilience
In view of the increasing damage caused by cyber attacks and EU directives such as the CRA, holistic cybersecurity is becoming indispensable. Dr. Christopher Tebbe, security expert, and Kilian Fröhlich, manager in OT security consulting, explain how...
