Wago
Data usage in the field
Wago is launching two new edge devices, an edge controller and an edge computer. The 752-8303/8000-0002 Edge Controller from Wago works with an ARM Cortex A9 quad-core processor and has an extensive range of interfaces.
This includes two Ethernet, one CANopen and two USB interfaces. A serial interface and four digital inputs/outputs are used to connect local devices or sensors. The Edge Controller is configured in the 'e!Cockpit' environment and thus integrates seamlessly into the product environment of Wago 's automation solutions.
The Edge Computer 752-9400 and 752-9401 each work with a quad-core Atom processor with 1.91 GHz and are equipped with a standard Debian Linux. The 64 Gbyte flash memory can be expanded by installing an SSD disk for very large amounts of data. As the Edge computers do not require a fan despite the extended temperature range of -20 to +60 °C, they are compact and easy to integrate. Standard software such as Node-Red can be used on all Edge devices. The devices communicate both on the factory floor and in the direction of the cloud using all standard protocols.
Would you like a little more?
First-hand news every week - that's what the Computer&AUTOMATION newsletter offers you.
© WEKA Trade MediaSubscribe to our weekly newsletter and keep your finger on the pulse of automation time. Once a week, on Tuesdays, we provide you with the latest news, exciting interviews, guest commentaries, application-oriented technical reports and new products. Stay up to date with us.
Our newsletters are of course free of charge and can be canceled at any time!
