Safety
Quelle: ifm electronic | Inka Krischke,
Standard and safety controller in one
The current controller from ifm electronic's 'ecomat' series for vehicles and mobile machinery has two independently operating 32-bit PLCs. One of them is certified as a safety controller (SIL2/PL d) with CANopen safety support.
© ifm electronic
The fast triple-core controllers also have a 6 MB application memory. Both controllers have scalable I/O assignments for standard and safety applications. Safe and non-safe controllers can also communicate with each other. In addition to the diagnostics-capable, multifunctional inputs and outputs, the device is equipped with two Ethernet ports and four CAN interfaces. The CAN interfaces support all important bus protocols (CANopen, CANopen Safety and J1939) as well as transparent and pre-processing data exchange. Codesys programming (version 3.5) enables the control functions to be integrated into the application program. All inputs and outputs can also be configured as safe channels if required. The metal housing also features a mobile-capable and coded central connector.
Logistics systems
New products for Logimat 2019
What is currently happening on the market in the areas of material flow and process management? Computer&AUTOMATION has compiled an excerpt of what exhibitors are showing at the Logimat 2019 logistics trade fair in Stuttgart in a series of...
Box PCs
IoT device for logistics
The new 'Vehicle Computer Compact M8' embedded box PCs from Syslogic have no moving parts, are shock and vibration resistant and are designed for an operating temperature range of -40 to +85 °C.
Embedded PCs
Suitable for vehicle installation
With the Nuvo-5100VTC, Industrial Computer Source presents an embedded PC that is E-Mark and EN-50155-certified and is therefore suitable for installation in vehicles. The devices are equipped with sixth-generation Intel Core i7, i5 and i3 CPUs.
Tablet PCs
Optional UPS module available
The outdoor tablet PC model 'UPC-F12C-ULT3' from Comp-Mall in an aluminum housing can be used as a mobile or stationary device and is protected against dust and splash water thanks to its all-round IP65/IP66 protection class.
