Safety controls
Quelle: Inter Control | Inka Krischke,
Safe and standard functions separated
Inter Control has further developed the digsy fusion S safety controller.
© Inter Control
The hardware and software structure of the TÜV Süd-certified safety controller is designed to ensure that safe and standard functions are separated without feedback. Functionally safe sensors are connected via CANopen Safety as a safe fieldbus, digital/analog inputs (dual-channel) and digital/analog inputs with internal diagnostics (single-channel). The controller with PL d meets the current requirements in accordance with EN ISO 13849:2016. Codesys version 3.5 SIL2 provides the user with the standard development environment for mobile automation. The safety controller has Ethernet and USB interfaces. The four CAN bus interfaces can be used with the CANopen, CANopen Safety and J1939 protocols or with proprietary protocols. The controller has an extensive file system for data logging.
Logistics systems
New products for Logimat 2019
What is currently happening on the market in the areas of material flow and process management? Computer&AUTOMATION has compiled an excerpt of what exhibitors are showing at the Logimat 2019 logistics trade fair in Stuttgart in a series of...
Box PCs
IoT device for logistics
The new 'Vehicle Computer Compact M8' embedded box PCs from Syslogic have no moving parts, are shock and vibration resistant and are designed for an operating temperature range of -40 to +85 °C.
Embedded PCs
Suitable for vehicle installation
With the Nuvo-5100VTC, Industrial Computer Source presents an embedded PC that is E-Mark and EN-50155-certified and is therefore suitable for installation in vehicles. The devices are equipped with sixth-generation Intel Core i7, i5 and i3 CPUs.
Tablet PCs
Optional UPS module available
The outdoor tablet PC model 'UPC-F12C-ULT3' from Comp-Mall in an aluminum housing can be used as a mobile or stationary device and is protected against dust and splash water thanks to its all-round IP65/IP66 protection class.
Control units
Freely programmable
The ESX-4CS-GW is the first product in the fourth generation of control units from Sensor-Technik Wiedemann. As a communication gateway, it offers six CAN interfaces, a 4-port Ethernet switch, a LIN and an RS232 interface.
