Panel PCs
Quelle: TL Electronic | Lukas Dehling,
Completely scalable
The G-Win series from TL Electronic can be flexibly scaled by the user from a range of display sizes and types, processors, equipment features and I/O options.
© TL Electronic
The range and modular design of the Panel PCs with protection class IP65 to IP67 simplifies configuration for stationary and vehicle-mounted applications. Both projected capacitive multi-touch fronts and more cost-effective 5-point resistive touchscreens in seven diagonals from 17.8 cm (7 inches) to 48.3 cm (19 inches) are available for the operating unit. The range of processors extends from the Freescale Cortex A9 i.MX 6 quad-core to Intel's Celeron N2930 and Core i5 5200U. The G-Win series operates fanlessly in a temperature range between -25 and +60 °C. In terms of shock and vibration resistance, the Panel PCs meet the MIL-STD-810 military standard. Various waterproof connection cables are available for the all-round IP65-protected devices.
Logistics systems
New products for Logimat 2019
What is currently happening on the market in the areas of material flow and process management? Computer&AUTOMATION has compiled an excerpt of what exhibitors are showing at the Logimat 2019 logistics trade fair in Stuttgart in a series of...
Box PCs
IoT device for logistics
The new 'Vehicle Computer Compact M8' embedded box PCs from Syslogic have no moving parts, are shock and vibration resistant and are designed for an operating temperature range of -40 to +85 °C.
Embedded PCs
Suitable for vehicle installation
With the Nuvo-5100VTC, Industrial Computer Source presents an embedded PC that is E-Mark and EN-50155-certified and is therefore suitable for installation in vehicles. The devices are equipped with sixth-generation Intel Core i7, i5 and i3 CPUs.
Tablet PCs
Optional UPS module available
The outdoor tablet PC model 'UPC-F12C-ULT3' from Comp-Mall in an aluminum housing can be used as a mobile or stationary device and is protected against dust and splash water thanks to its all-round IP65/IP66 protection class.
Control units
Freely programmable
The ESX-4CS-GW is the first product in the fourth generation of control units from Sensor-Technik Wiedemann. As a communication gateway, it offers six CAN interfaces, a 4-port Ethernet switch, a LIN and an RS232 interface.
