Container shuttle
Quelle: Kardex Group | Lukas Dehling,
Weight of 50 kg can be accommodated
With its Kardex Mlog Division, the Kardex Group presents the universally applicable MCrossDrive 3D container shuttle. According to the manufacturer, the container shuttle focuses not only on efficiency and dynamics but also on flexibility and scalability.
© Kardex Group
The shuttle is designed to hold containers weighing 50 kg with a standard size of 400 mm × 600 mm. Directional changes of 90° are made via an automatic axis change, and the level in the rack can also be changed via lifting stations. This means that the system is neither aisle-bound nor level-bound and can move practically freely in the longitudinal, transverse and vertical directions. According to the manufacturer, this means that variable and high-performance system solutions can be implemented even in unfavorable spatial conditions and previously unused space can be converted into valuable storage space. In the basic version, the system consists of a rack dimensioned according to the required capacity, an MCrossDrive 3D and a vertical lifter. It is also possible to integrate the vehicle as an alternative to conventional conveyor technology, for example in order picking or buffer warehouses.
Logistics systems
New products for Logimat 2019
What is currently happening on the market in the areas of material flow and process management? Computer&AUTOMATION has compiled an excerpt of what exhibitors are showing at the Logimat 2019 logistics trade fair in Stuttgart in a series of...
Box PCs
IoT device for logistics
The new 'Vehicle Computer Compact M8' embedded box PCs from Syslogic have no moving parts, are shock and vibration resistant and are designed for an operating temperature range of -40 to +85 °C.
Embedded PCs
Suitable for vehicle installation
With the Nuvo-5100VTC, Industrial Computer Source presents an embedded PC that is E-Mark and EN-50155-certified and is therefore suitable for installation in vehicles. The devices are equipped with sixth-generation Intel Core i7, i5 and i3 CPUs.
Tablet PCs
Optional UPS module available
The outdoor tablet PC model 'UPC-F12C-ULT3' from Comp-Mall in an aluminum housing can be used as a mobile or stationary device and is protected against dust and splash water thanks to its all-round IP65/IP66 protection class.
Control units
Freely programmable
The ESX-4CS-GW is the first product in the fourth generation of control units from Sensor-Technik Wiedemann. As a communication gateway, it offers six CAN interfaces, a 4-port Ethernet switch, a LIN and an RS232 interface.
