Keyboard modules
Quelle: Graf-Syteco | Lukas Dehling,
Flexible installation
The latest version of the Graf-Syteco K2 series keypad modules can be freely programmed.
© Graf-Syteco
The keypads, which are integrated into the automation environment via an integrated CAN interface, not only work passively, but can also trigger various actions when a button is pressed, depending on the status of the machine. The keypads have e1 approval and meet protection class IP65. They are therefore particularly suitable for mobile machines in the agricultural, construction and municipal sectors, for example. Together with the manufacturer's operating and control units, operating solutions for mobile machinery can be implemented. Depending on the type, the modules consist of four or five short-stroke buttons and one or two digital potentiometers. They can be installed both vertically and horizontally. The brightness of the keypad lighting can be dimmed. Thanks to the free programmability, many functions can be implemented without the need for the control unit. For example, it is only possible to execute a function when a button is pressed if the machine is moving at no more than a specified speed. Programming can be carried out either in C or with the GSVisu software.
Logistics systems
New products for Logimat 2019
What is currently happening on the market in the areas of material flow and process management? Computer&AUTOMATION has compiled an excerpt of what exhibitors are showing at the Logimat 2019 logistics trade fair in Stuttgart in a series of...
Box PCs
IoT device for logistics
The new 'Vehicle Computer Compact M8' embedded box PCs from Syslogic have no moving parts, are shock and vibration resistant and are designed for an operating temperature range of -40 to +85 °C.
Embedded PCs
Suitable for vehicle installation
With the Nuvo-5100VTC, Industrial Computer Source presents an embedded PC that is E-Mark and EN-50155-certified and is therefore suitable for installation in vehicles. The devices are equipped with sixth-generation Intel Core i7, i5 and i3 CPUs.
Tablet PCs
Optional UPS module available
The outdoor tablet PC model 'UPC-F12C-ULT3' from Comp-Mall in an aluminum housing can be used as a mobile or stationary device and is protected against dust and splash water thanks to its all-round IP65/IP66 protection class.
Control units
Freely programmable
The ESX-4CS-GW is the first product in the fourth generation of control units from Sensor-Technik Wiedemann. As a communication gateway, it offers six CAN interfaces, a 4-port Ethernet switch, a LIN and an RS232 interface.
