Control units
Quelle: Sensor-Technik Wiedemann | Lukas Dehling,
Freely programmable
The ESX-4CS-GW is the first product in the fourth generation of control units from Sensor-Technik Wiedemann. As a communication gateway, it offers six CAN interfaces, a 4-port Ethernet switch, a LIN and an RS232 interface.
© Sensor technology Wiedemann
With an additional 14 analog and digital inputs and outputs in the standard configuration, the freely programmable controller can also take on small sensor-actuator management tasks. In the fourth generation of ESX controllers, the Infineon Aurix processor, which operates with three independent 32-bit triple-core processors at 300 MHz, ensures that tasks are processed quickly. The communication gateway complies with the CE and E1 conformity standards as well as the standards of the automotive, agricultural and construction machinery industries. Approval for safety-related applications in accordance with PLd (DIN EN ISO13489-1 2008-12) or SIL 2 (IEC 61508 Edition 2.0 2010-04) is planned. C and IEC 61131 are supported as programming languages. The respective development environments for this are Codesys and openSYDE.
Logistics systems
New products for Logimat 2019
What is currently happening on the market in the areas of material flow and process management? Computer&AUTOMATION has compiled an excerpt of what exhibitors are showing at the Logimat 2019 logistics trade fair in Stuttgart in a series of...
Box PCs
IoT device for logistics
The new 'Vehicle Computer Compact M8' embedded box PCs from Syslogic have no moving parts, are shock and vibration resistant and are designed for an operating temperature range of -40 to +85 °C.
Embedded PCs
Suitable for vehicle installation
With the Nuvo-5100VTC, Industrial Computer Source presents an embedded PC that is E-Mark and EN-50155-certified and is therefore suitable for installation in vehicles. The devices are equipped with sixth-generation Intel Core i7, i5 and i3 CPUs.
Tablet PCs
Optional UPS module available
The outdoor tablet PC model 'UPC-F12C-ULT3' from Comp-Mall in an aluminum housing can be used as a mobile or stationary device and is protected against dust and splash water thanks to its all-round IP65/IP66 protection class.
