Mushroom
Bücker Nils | Inka Krischke,
Protection for the weakest link
Industrial security is a 'moving target'. This means that everyone involved must also keep moving and constantly put the available tools to the test. This also applies to user administration.
© iStock.com/metamorworks
In order to be able to counter different threat scenarios flexibly, security strategies consisting of several layers of protection are implemented nowadays: At the core are the automation components. This is followed by the network, via which these components can communicate with other components or even with an ERP system. The top layer is the factory, which is shielded from the outside by a firewall concept.
However, such concepts are not enough to provide all-round protection for systems. Threats can also come from within, i.e. from employees themselves. Therefore, physical protection against unauthorized access to network devices such as firewalls, switches and automation components forms the basis of any security strategy. Only if these devices are not freely accessible can they be prevented from being manipulated on site.
A simple measure can be to install all these components behind closed doors, for example in lockable switch cabinets or distribution boxes. This also significantly reduces the risk of operating errors by unauthorized personnel.
The situation is different directly at the machine and in the machine parks: If operation, set-up, maintenance and repair are to be economical, direct and, above all, safe human access to the machine or machinery is required. Different roles and authorizations are associated with the aforementioned activities on the machine - from machine operator to service technician. At this point, the operator needs a user management system that regulates access to the machine according to authorizations or skills. The Human Machine Interface (HMI) serves as the operator interface.
Security and user management rules
The normative framework for the implementation of secure user management is already regulated in principle: There is the NIS 2.0 (Directive on the Security of Network and Information Systems). The first EU-wide law on cybersecurity, the NIS Directive, came into force in 2016 and helped to achieve a higher and more consistent level of security for network and information systems across the EU. The NIS 2.0 and the IT Security Act 2.0, which came into force in July 2015, primarily relate to critical infrastructures. The topic of industrial security is also included in the new Machinery Regulation. It will become binding from the Machinery Directive in 2023 at the earliest. This still gives manufacturers in particular a certain amount of leeway - but there is still an acute need for action in the search for practicable solutions.
Clear specifications through IEC 62443-4-2
Industrial security is anchored in the new Machinery Ordinance.
IEC 62443-4-2 prioritizes the identification and authentication of human users as the most important point, followed - and closely interwoven - by usage control. Usage control means the enforcement of authorization and the mapping of authorization to the respective roles (operate, maintain, repair, ...).
One thing is certain: People are the weakest link in the security network. User administration must therefore not only be solved and supported organizationally, but also technically. This is where classic user administration comes in, which is implemented with local user administration in the components. The disadvantage here is often the limited number of user accounts due to limited storage resources and the defined rigid assignment of privileges to roles or groups - for example for administration and diagnostics.
This is only partially efficient for the future. For example, traditional user administration requires regular changes to passwords and password policies. This ongoing task must also be documented correctly. Added to this are the many different components from various manufacturers and, last but not least, the different approaches of machine manufacturers and operators. A practicable implementation of all security rules and measures requires integration into a user management system.
What solutions does IT offer?
Various IT solutions are available for user administration. LDAP (Lightweight Directory Access Protocol) is a well-known network protocol for querying and changing information from distributed directory services and is also the de facto industry standard for authentication, authorization and address and user directories. Most software products that have to deal with user data and are relevant on the market support the protocol.
LDAP can also be easily integrated into Windows environments (Active Directory), is widely used and is also suitable for WiFi WPA2 Enterprise.
Another IT solution is 'Radius'. Radius stands for Remote Authentication Dial In User Service and is a network protocol for user authentication. In the past, it was primarily of interest to Internet service providers (ISPs). The network protocol performs three main functions: authenticating users or devices before they gain access to a network; authorizing these users or devices for certain network services; and tracking access to these services (important for user management).
For LDAP and Radius, the secure variants LDAPS (LDAP Security) and RadSec (Radius Security) should be used. But there are disadvantages: RadSec, for example, is not widely used. In addition, RadSec and LDAPS are based on asymmetric cryptography, which increases the resource requirements in the control level components, which in turn increases the hardware costs, as an on-site server must also be integrated into the solution. Another disadvantage is that if the LDAP or Radius server is under the management of the operator, the machine manufacturer cannot simply maintain users for remote access - and vice versa.
Away from hardware, towards the cloud
The general trend towards cloud solutions is also interesting for the topic of user administration. The advantage of a cloud solution is that it saves space in the components. In addition, no local LDAP or Radius server is required. Even complex policies can be implemented in the cloud. Machine builders and operators can share user administration (for example, thanks to the multi-client capability of the cloud solution). In addition, a cloud connection could be used for other services.
But there are disadvantages here too: TLS (Transport Layer Security) or a comparable secure protocol is required for communication with the cloud, which in turn increases resource requirements. In addition, the necessary internet connection represents a potential security gateway for attackers. And, of course, 'end-to-end availability' plays an important role when it comes to the cloud.
Although a cloud solution could solve existing problems, new challenges arise at the same time.
User administration with certificate
User management must be solved and supported not only organizationally, but also technically.
Another option, which is already being used in automation, is user management without the cloud using a certificate, a type of digital ID. This certificate stores the identity, validity period, issuer, a type of 'public key' and the authorizations (in the form of X.509v3 extensions). As a security solution, this would result in a combination of the certificate and a readout unit on the machine.
X.509 is an ITU-T standard for a public key infrastructure. It can be used to create digital certificates. X.509 is a standard application, so there is no vendor lock-in. However, extensions must be documented. The whole thing is compatible with a standard web browser - TLS can use X.509 certificates for authentication. A certificate can be valid for a single component or for a group of components; it can also be used locally on the component (e.g. smartcard via NFC).
A private key and certificates can be securely stored on smartcards (e.g. USB tokens). A direct connection to the higher-level certification authority is not absolutely necessary. The certificates can be easily distributed via email or download, for example, and can only have a short validity period if required, for example during a service visit to the customer.
However, there are also restrictions here: The component requires a secure time source to check the validity period. An online connection may be required to query a revocation list. This can become complex under certain circumstances if, for example, intermediate certification authorities are to be used and certification authority certificates need to be exchanged. And as this is a component solution directly on the machine, the resource requirements on the component remain high.
Component versus application level
The task of 'user administration' implies an ongoing process: without users there is no administration and without administration there are no users. It quickly becomes clear that the user - the human being - cannot do without a well thought-out and, above all, simple technical implementation of authentication management. Organizationally, this can no longer be solved efficiently today. The technical solution must be comprehensible for everyone involved and therefore easy to implement, otherwise users will unfortunately usually bypass it and not implement it in accordance with the rules.
The author: Nils Bücker works in Product Management Software and Technologies at Pilz in Ostfildern.
© Mushroom
In terms of user-friendliness, user management using a digital certificate is attractive. Local user management is the easiest to implement in terms of product requirements. A solution via external servers is somewhere in between. In addition, access at component level is often not necessary for the operator - this speaks in favor of a solution that runs at application level.
If IEC 62443-4-2 is consulted, the interpretation of the requirements according to IEC 62443-4-2 is still relatively unclear and offers component manufacturers room for interpretation. How user management is ultimately implemented is not specified. However, well thought-out user management that is anchored in processes is an essential key to ensuring security. Operators, plant engineers and manufacturers are looking for practicable and economical solutions that comply with the guidelines set out in the standards.
Hima Group
CEO appointed for Sella Controls
The Hima Group has appointed Carl Ramsden as CEO of Sella Controls with effect from October 1, 2025. According to Hima, this newly created position represents an important milestone in the further integration of the British company into the Group.
Bihl+Wiedemann
Innovation partner for automation
Bihl+Wiedemann is a medium-sized, owner-managed company - founded in 1992 by Jochen Bihl and Bernhard Wiedemann in Mannheim. It develops and manufactures complete solutions for functional safety and data communication in machines and systems.
Hima Group
Growth course continued
The Hima Group, a provider of safety-related automation solutions, grew significantly in the 2024 financial year, driven in part by international expansion and an increasing focus on digital solutions.
