Georg Schlegel
Operating temperature from -25 to +70 °C
Schlegel has added an emergency stop for the 22.3 mm installation opening to the 'Shortron M12' series. The small and compact FRVKOO_M001 with rotary release has protection class IP65/IP67 from the front and IP65 from the rear and is therefore also suitable for environments with splash water.
The two contacts (AgNi) of the emergency stop are designed as normally closed contacts (NC) and are positive opening in accordance with EN60947-5-1. The emergency stop has a service life of up to 50,000 switching cycles and is designed for operating temperatures from -25 to +70 °C.
The 4-pin M12 connection is A-coded and connected to the emergency stop via a 25 cm long PUR cable. According to the supplier, the electrical characteristics are within a range of maximum Ue 35 V operating voltage and operating currents of Ie 4A (AC15) or Ie 2A (DC13). The emergency stop complies with the EN ISO 13850 and EN 60947-5-5 standards.
