Rafi at the SPS 2022
Yvonne Junginger,
Micro push-button with two-channel contact system
The short-stroke pushbuttons in the Micon 5 series from Rafi are now also available in the Micon 5 Safety version with a two-channel contact system.
© Rafi
The push-buttons in the series have the same dimensions as Micon 5, but integrate two isolated NC and NO contacts. Thanks to an optimized sealing system, the micro push-buttons achieve protection class IP54 or IPx7 and, with a temperature resistance of -40 to +125 °C, meet the current requirements of the automotive industry. They have an SMT connection for PCB assembly and are suitable for potting, painting and nano-coating.
Like the standard versions, the pushbuttons from Rafi offer a switching-safe gold contact system and tactility: depending on the version, the pushbuttons, which are available for different actuating forces, guarantee up to 1 million switching cycles. Thanks to the identical dimensions, the Micon 5 accessory range of plungers and keycaps is also available without restriction for the new version.
SPS 2022: Hall 7A, Stand 544
Electrosil
Dynamic haptic feedback
With the 'Smart-Knob Mini', Elektrosil is expanding its series of intelligent rotary pushbuttons with a compact solution. The rotary encoder combines rotation and pressure functionality in a robust housing with IP65 protection and a glass surface.
