Posic
Yvonne Junginger,
FR4 scale for inductive encoders
Posic launches two new benchmarks for the ID1102L and ID4501L linear encoders.
© Posic SA
The TPLS04 scale has a length of 26 mm, while the TPLS05 is 205 mm long. The scale width of 4.5 mm and the thickness of 0.77 mm match the very small dimensions of the encoders, making them suitable for applications with tight installation spaces. The scale is an FR4 printed circuit board with copper strips with an accuracy of ±10 µm and a resolution of up to 0.02 µm.
It does not attract ferromagnetic dust/particles, is insensitive to moisture, grease, oil and liquids, does not need to be cleaned before operation and also works in strong magnetic fields. According to Posic, the scale has an adhesive backing with a release film for quick and easy installation. Typical applications include linear direct drives, Z-movement in pick-and-place machines, robotics, life science devices, microfluidics, microscope stages, piezo motors and plunger coils.
SPS 2022
The supporting program is available
The SPS starts on November 8 in Nuremberg. Around 1,000 exhibitors have announced their attendance. A highlight of the trade fair will be the theme talk with Minister President Dr. Markus Söder on the second day of the fair.
