Wibu-Systems
Licensing in edge & cloud computing
When applications were moved to the cloud, it was thought that the issue of licensing had been resolved. But not everything is in good hands in the cloud. When operating containers, licensing has now become even more important due to the associated scaling.
In the distant past, software was delivered on floppy disks, later on CDs and DVDs. In this case, users installed the software on their personal computers. Today, these solutions are referred to as on-premises and pose challenges for manufacturers both then and now. One of these is the user's system requirements: the appropriate computing power is needed to run the software, and problems can also arise due to interaction with other software installed on the computer. Another, even more important challenge from the manufacturer's point of view is preventing unauthorized use of the software. Copy-protected floppy disks or CDs were once introduced for this purpose. A dongle is often used for higher-priced software. The software can then be installed as often as required, but only runs where the dongle is connected. Computer-bound activations are also used for this type of software. Copy-protected floppy disks and CDs can only be found in museums these days.
SaaS in the cloud is catching on
After several more or less successful attempts to make software available for use online - for example under the name Application Service Providing, or ASP for short - Software as a Service (SaaS) has now established itself in the cloud. Applications such as online maps or online translation tools have completely replaced their on-premises versions. With this cloud software, the application is usually operated by the manufacturer and made available to users online. Users only need a browser, in some cases a thin client. SaaS thus reduces the requirements for local computers, opens the door to software on mobile devices and changes the requirements for protection and licensing. In contrast to on-premises software, no copy protection is required here and licensing can be linked to user identification (login). The development tools used by programmers have also changed when moving to the cloud: While on-premises applications are often written in C++ or .NET, many different programming environments are now used with Python, JavaScript & Co. SaaS solutions in the cloud are generally already highly scalable due to their architecture.
The "cloud first" trend is also spilling over from the end customer environment to B2B applications. One example of this is predictive maintenance applications for control systems and plants.
The solution in between: Edge
From the manufacturer's point of view, the new cloud world could be so wonderful if issues such as cloud availability, required bandwidth, latency times and, above all, legal issues such as "Where is my data?" did not stand in the way of cloud computing. The compromise solution is edge computing. Here, the cloud solutions run at the edge of the cloud on the user's premises and only exchange minimal data with the cloud, if any at all. Manufacturers want to take advantage of all the benefits of their cloud software: Scalability and flexibility in the development environment. Thanks to Docker and other container solutions, it is technically relatively easy to implement a cloud solution as an edge solution. The various services are provided together with all the necessary software components in individual containers and do not require complicated installation processes or dependencies on other software on the user side. This isolation also prevents interactions with software from other manufacturers.
One point is often overlooked in this type of migration project and is often added as a last-minute change request under time pressure: the changed requirements for licensing and software protection. While copy protection and intellectual property protection are irrelevant for cloud solutions that are operated by the manufacturer, this point comes into play with an edge solution: similar to an on-premises application, the application runs in the care of the user. In addition to familiar requirements from the on-premises world, new licensing requirements are also added, such as how to map the scalability of the systems in the license. Similar to the on-premises world, a non-copyable, secure anchor is required for licensing.
Licensing in Edge Computing
Edge devices occupy a special position. The manufacturer supplies a ready-made solution consisting of hardware and software that connects the local system landscape with the systems in the cloud and controls the data flow. Licensing can be carried out either via the cloud systems contacted, which enable user identification via login, or as a classic on-premises license on the device itself. If certificates with private keys worthy of protection are used for encrypted communication - either with local devices or with the cloud - secure anchors are used. These can be TPM chips or dongles, the latter with the option of storing licenses and certificates at the same time.
On the devices in the local system environment, it depends on the exact application scenario, the manufacturer's need for protection and user acceptance as to which licensing type can be used. The systems are often capable of running several containers in parallel, which raises the question of how to control and regulate the number of containers in operation and thus the services running in them.
The manufacturer has optimum control if systems with an integrated security chip and licensing mechanism are used or a dongle can be plugged into the device. The license is then located in the device in a secure chip and the cryptographic functions from the containers can be used directly or via an explicitly created container for license use.
If it is possible to use a license from a cloud-based licensing system via an edge device, the manufacturer can also be sure that the licenses are counted correctly. The prerequisite is a permanent connection to the Internet and the unrestricted availability of the cloud license.
For software-based licensing of the application running in a container, you need to take a closer look at the matter and find a suitable solution for your own use case. Containers have been developed to abstract everything as well as possible and to restrict data traffic to the host or other containers to desired transfers. This means that the system features normally used cannot be read and it is also not possible to persist the license data.
In order to implement software-based licensing, however, a secure anchor is required in the container that can be bound to a license. The license data must then be stored within the system in such a way that it is retained in the container. These requirements are not directly compatible with scaling, i.e. starting several containers in parallel. In these cases, the license is operated in a separate licensing container, which then provides the licenses for the other containers on the local system. In order to obtain a secure anchor, this licensing container will have to run with certain rights. It is important to be aware that the desired abstraction of containers is in direct conflict with the manufacturer's desire for control and licensing. A solution therefore always requires a willingness to compromise.
With the Codemeter solution offered by Wibu-Systems, the licensing systems in the dongle, software-based licensing and cloud license are cryptographically identical and can therefore be adapted according to the area of application and the customer's wishes; the applications or scripts protected with Codemeter Protection Suite do not have to be touched for this. The application containers with the protected software, which may run multiple times, are connected to the license container via a separate network in the container world. This means that the cryptographic calls from the application containers can access the license and are transported in isolation. The license container contains either a connection to the built-in security chip from Wibu-Systems or to the cloud operated by Wibu-Systems. When using a software-based license, this license container requires access to the Docker socket for anchoring. The license information is persisted on the system via a named volume and therefore survives a version update of the license container, for example.
License server in the private cloud
The author: Wolfgang Völker is Director Product Management & Support at Wibu-Systems.
© Wibu-SystemsIn some use cases, the containers no longer necessarily run on the company's own hardware, but are started in a private cloud from Microsoft or Amazon for simulation purposes, for example. In these environments, there are other options for binding licenses. With Codemeter, software-based licensing is therefore linked to the information provided by the provider about these systems. This binding to specific IDs is then robust against host changes etc.
Alternatively, a license server in the cloud operated by a trusted provider can be used. In this case, a virtual dongle is located in the cloud and the software in the container connects to this virtual dongle in encrypted form using a password file. The number of simultaneously running instances of the software in the containers is monitored via the license server in the cloud.
In addition to the ready-made solutions included in the Codemeter Runtime, the manufacturer can also provide its own bindings. This can be an enterprise license, for example, which enables customers of the software manufacturer to operate as many instances as they wish. Something like this could be implemented purely with an IP protection solution without the use of a license.
However, software can also be used around the globe without a license. For example, one user of Wibu Systems technology has implemented a link to a customer ID of the private cloud provider. This ensures that any number of instances can run in this customer's account in a specific data center.
As you can see, there are various possible solutions for different application scenarios. There is no one-size-fits-all answer that works for all scenarios. The right solution often turns out to be a combination of different options for the same software - depending on the application and regional requirements.
